I have a points shapefile, I buffer the points and use this to clip VRT Rasters. I need the output to retain the attributes passed from the point/buffer, which the clipped output does. However the clips retain georeference and place the clips within total images footprint if that makes sense. I tried converting to PNG (no world file option chosen) which works great but this loses all the attributes. Grateful for any suggestions.
I need to clip lots of rasters and use them as 'images' only. I don't want to keep any wordfile or locational data. Is there a way to remove this?
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
