Writing to multiple CityGML files results in an error (FME2020)
harmen_kampinga
Screenshot_1When I have created a CityGML writer and add another one with the same specs except for the file name, running the process ends in an error.
Both writers are separate. So it's not one CityGML writer writing two Feature Types (that won't work).
Those are the warnings and the only error I get:
2020-08-10 10:38:15|  13.3|  0.0|WARN  |Duplicate XML Schema attribute declaration found -  QName: 'xml:lang', schema URL: 'file:///C:/Program Files/FME2020/xml/schemas/CityGML/CityGML/2.0/3.1.1/smil/xml-mod.xsd'
2020-08-10 10:38:15|  13.3|  0.0|WARN  |Duplicate XML Schema attribute declaration found -  QName: 'xml:space', schema URL: 'file:///C:/Program Files/FME2020/xml/schemas/CityGML/CityGML/2.0/3.1.1/smil/xml-mod.xsd'
2020-08-10 10:38:15|  13.3|  0.0|WARN  |Duplicate XML Schema attribute group definition found -  QName: 'xml:specialAttrs', schema URL: 'file:///C:/Program Files/FME2020/xml/schemas/CityGML/CityGML/2.0/3.1.1/smil/xml-mod.xsd'
2020-08-10 10:38:15|  14.1|  0.0|WARN  |Duplicate XML Schema attribute declaration found -  QName: 'xml:lang', schema URL: 'file:///C:/Program Files/FME2020/xml/schemas/CityGML/CityGML/2.0/3.1.1/smil/xml-mod.xsd'
2020-08-10 10:38:15|  14.1|  0.0|WARN  |Duplicate XML Schema attribute declaration found -  QName: 'xml:space', schema URL: 'file:///C:/Program Files/FME2020/xml/schemas/CityGML/CityGML/2.0/3.1.1/smil/xml-mod.xsd'
2020-08-10 10:38:15|  14.1|  0.0|WARN  |Duplicate XML Schema attribute group definition found -  QName: 'xml:specialAttrs', schema URL: 'file:///C:/Program Files/FME2020/xml/schemas/CityGML/CityGML/2.0/3.1.1/smil/xml-mod.xsd'
Error running translation.
Best answer by virtualcitymatt
Ha! you are so right - I get something similar. No warnings but the same ERROR/Crash
Heres a simple test. If you disable either of the Writers in the Navagator pane then the worksapce works fine. Having two just failes.
I've been trying to figure out what was causing these random crashes for ages! Thanks for sharing you issue.
No issues in FME 2018.
@daveatsafe​  - Are you able to have someone take a look at this?
@Harmen Kampinga​  You should be about to workaround the issue by removing the second writer and using the fanout. You will need to create a filename attribute which is a bit annoying.
The other thing to try is to use the FeatureWriter. That may not have the same bug.
virtualcitymatt
Forum|alt.badge.img+35
  • August 10, 2020
harmen_kampinga
Thanks @virtualcitymatt​ ! Ah, good to find out that you have found it as an error also. Yeah, those are indeed probably the best solutions to work with. For now, I just deactivated the one and activated the other one to have it running. Good enough for me, but certainly not when you like to have that in production!
