Fix a minimum distance within a 2D point dataset
Hello,
I have a 2D set of points within which I want that no pair of points stay within a distance inferior to a threshold of my choice. The supplementary points have just to be deleted. How can I perform that?
Thank you in advance.
Best answer by dustin
dustin wrote:
What do you want to happen with the points if they are within the threshold? Delete one? Move them apart?
You can use the NeighborFinder with the Candidates Only option. Then set the Maximum Distance parameter to a published parameter. The points that fall outside the tolerance would be from the UnmatchedBase portimage
dustin
Forum|alt.badge.img+30
  • January 9, 2023
Just delete them.
dustin
  • January 9, 2023
Works perfectly. Thank you !
