Neighborhood finder should match only one time
boubcher
Forum|alt.badge.img+11
using neighborhood find we need the workspace when the candidate find the base we don't want this base to be used again in the process even if it fit the transformer setting
Ex: I have 4 polygons and 5 Points we need to find a point within a distance of 1 m to polygon, 2 of those points are within the distance, our goal is the process when we found the first match the second one should not be considered
the parameter( number of neighbors to find ) is not working since each point will find 1 neighborhood, if one point find polygon, that polygon shouldn't not be used by another point
Thanks
danilo_fme
Forum|alt.badge.img+41
Hi @boubcher​
Did you try to use the custom transformer SpatialSorter?
Thanks,
boubcher
  • December 21, 2021
danilo_fme wrote:
Hi @boubcher​
Thanks,
Thanks Danilo
danilo_fme
  • December 21, 2021
boubcher wrote:
Thanks Danilo
You are Welcome @boubcher​
