FME server password policy?
Is it possible to enforce the minimum password length for FME server from application?
If yes, what is password policy and how to enforce?
Best answer by david_r
As far as I know, this isn't possible using the built-in FME Server authentication.
If you use an external authentication system, e.g. Active Directory, you should look into implementing the policies there.
  • September 6, 2017
  • September 6, 2017
Thanks David!
do you know, what is default FME server minimum password length?
  • September 6, 2017
sekarraj123 wrote:
Thanks David!
It's 1 character. The only restriction seems that you cannot leave the password blank.
