Unable to double select transformer
gregbensnoco
I can click on the desktop and add a transformer but when I double-click the title bar of the transformer, nothing happens.  I can’t click and move a transformer either.  I can edit a transformer in the left Navigator.  I can’t add connectors between transformers.
Reinstalled same version (2023.1.1.1) because that’s the version we use.  Still same problem.  I can run an existing workspace but the transformers seem to be unselectable.
I don't have this problem when FME Workbench is on my laptop screen and not my external monitor.  I've built dozens of workspaces on this external monitor without issue.  Problem started last week.  In Display Settings I extended the laptop display to the external monitor.
It turns out if I change Display Settings to Show only on 2 and back to Extend Displays the FME workspace is fine.
danilo_fme
Forum|alt.badge.img+45
  • April 25, 2025
Hi ​@gregbensnoco - it’s strange situation.
gregbensnoco
  • April 26, 2025
