Comparison FME Flow silent install properties to FME Server
helmoetz
Forum|alt.badge.img+14
Hi, we are silent installing FME Flow for the first time. We used to install FME Server using a silent install script, which uses the next installation properties:
FMESERVERHOSTNAME
INSTALLDIR
FMESERVERSHAREDDATA
PGDATA
WEBSERVERHOSTNAME
SERVLETPORT
DATABASEPASSWORD
In the new FME Flow silent install instructions, a different set of installation properties is used. I think the properties above compare to
COREHOSTNAME (changed)
INSTALLDIR (unchanged)
FMEFLOWSHAREDDATA (changed)
PGDATA (unchanged)
EXTERNALHOSTNAME (changed)
SERVLETPORT (unchanged)
DATABASEPASSWORD (unchanged).
My questions:
  • Can this be confirmed?
  • Would it be possible to get a link to the location where this is documented?
Best answer by luke.hicks
Hi ​@helmoetz,
We do not have a direct comparison chart available, but you can view old documentation to manually compare the two. Here is how you do it:
2023.0 or Newer:
https://docs.safe.com/fme/<FME VERSION>/html/FME-Flow/AdminGuide/Silent-Install-Windows.htm
Older than 2023.0:
https://docs.safe.com/fme/<FME VERSION>/html/FME_Server_Documentation/AdminGuide/Silent-Install-Windows.htm
Replace <FME VERSION> with the version you are looking for. If you were looking for a Linux version, you can access it from the side tab from the documentation link.
Cheers,
   - Luke
damiobasa
  • April 4, 2025
Hi ​@helmoetz yes this can be confirmed and you can review this in the installation properties section of this document
helmoetz
  • April 6, 2025
Thanks ​@damiobasa I was just wondering if there is a complete list comparing the FMEFlow install properties to the old FMEServer install properties…
luke.hicks
  • April 9, 2025
Hi ​@helmoetz,
2023.0 or Newer:
Older than 2023.0:
Cheers,
   - Luke
