InlineQuerier not working on FME server 2022
  • March 31, 2025
  • 16 views
sg2171
For some reason when I run inlinequerier on FME server 2022 I get the following error.
64
2025-3-31 16:49:13 | InlineQuerier (InlineQueryFactory): The clause 'USE_FMEOBJECTS Yes' within 'FACTORY_DEF {*} InlineQueryFactory FACTORY_NAME { InlineQuerier } USE_FMEOBJECTS Yes TABLE_DEF Swap_Data Title<comma>text<comma>Hyperlink<comma>text<comma>Region<comma>text<comma>Status<comma>text<comma>Event_ID<comma>integer<comma>Usid<comma>text<comma>Market<comma>text<comma>SubMarket<comma>text<comma>ClosedOut<comma>text<comma>ErcNode<comma>text<comma>SSD<comma>text<comma>SSV_Ready_Date<comma>text<comma>Q_5640T_Date<comma>text<comma>FA<comma>integer<comma>County<comma>text<comma>SSV_Rejection_Note<comma>text<comma>sharepoint_item_id<comma>integer QUERY_DEF Swap_Data SQL_ENCODED Select<space><quote>County<quote><lf>From<space><quote>Swap_Data<quote> GEOMETRY_SELECTION FIRST INPUT Swap_Data FEATURE_TYPE Swap_Data_SHAREPOINT_1_1_wuz7majgeOo=' is not recognized by the factory 'InlineQueryFactory'
My desktop version is 2023.2. This was done to get my JDBC connection to work with DEEP.
Not sure about this specific error but publishing workspaces from a higher version of Form (desktop) to Flow (server) is known to cause errors and is not supported. See FME Versions and Workspace Compatibility
