GeoApps Version
With this transformer, you can easily request the version of GeoApps. This connection is useful for verification of your connection.
Prerequisites
To use this transformer, you need to have an active GeoApps subscription and a user account with enough permissions to run the jobs. In addition, you need to first set up a web connection to GeoApps from FME. You can find the web connection in the FME Hub at https://hub.safe.com/publishers/mapgear/web-connections/geoapps.
How to use?
Add the transformer in your workspace, and configure the parameters. You need to set up two parameters: the tenant name, and the web connection to GeoApps. After setting up, you receive three output parameters: major, minor and patch version level.
Questions?
Do you need any help? Feel free to contact us at support@geoapps.nl.
Would you like to know more? Click here to find out more details!
