Create vertex on existing line feature
joe_cast
Hello all,
I have some point (electricity poles) and line (overhead conductors) features which I need to connect up for our utility network model.
I am trying to insert a vertex on the line at the nearest point to the pole. I have a neighbor finder and vertex creator, but neither are actually adding a vertex to the line (the neighbor finder has insert vertex on base feature set to yes).
Is there something I am missing or another way to go about this?
thanks.
crutledge
Forum|alt.badge.img+31
  • March 19, 2025
Hi ​@joe_cast I think the PointOnLineOverlayer would work well for you here:
I hope this helps. Good Luck!
joe_cast
  • March 19, 2025
Thanks, Ill try that. The notes say it splits the line feature which I dont want, so this may not work for this application.
geomancer
Forum|alt.badge.img+47
  • March 19, 2025
Strange, the NeighborFinder should just insert an extra vertex on the line.
dustin
Forum|alt.badge.img+30
  • March 19, 2025
Might consider the AnchoredSnapper with the Segment snapping option. Anchor would be points, Candidates would be lines.
crutledge
  • March 19, 2025
Ah yes. You could use a LineCombiner or FeatureJoiner after that point. The assembled lines should keep the vertex.
And as ​@geomancer points out your original method should be working. Maybe with that advice you will get the vertex on the line. Good Luck!
DanAtSafe
Forum|alt.badge.img+18
Hi ​@joe_cast and ​@geomancer The NeighborFinder only inserts one vertex from the closest candidate.  FYI there’s an enhancement request to insert all points within tolerance, FMEENGINE-15502.  The AnchoredSnapper does the same without having to reconnect the lines.
joe_cast
  • March 27, 2025
Thanks for the suggestions all. The neighbor finder was adding a vertex after all, but I had to send it through a feature writer to see them in arcgis. Good learning opp for me :)
