Issues with uploading New Item on my FME Hub Publisher Account
  • February 26, 2025
  • 36 views
evoteck
Forum|alt.badge.img+13
I am trying to  upload New Item (.fmx) on my FME Hub Publisher Account, but it is showing error of upload failed.
Best answer by saraatsafe
Updating this thread in case anyone comes across the same issue:
Custom transformers need to be exported as such, instead of simply being saved as an .fmx.
Select the object(s) that you want to include in your custom transformer, then right-click and select "Create Custom Transformer...", then export it by navigating to File > "Export as Custom Transformer...". Make sure you fill in both the Category and Description fields, since these are fields required by the FME Hub.
Further details can be found here:
Creating a Custom Transformer and Exporting a Custom Transformer
saraatsafe
  • February 27, 2025
Hi ​@evoteck, would you be able to share the transformer with us? It’d be great if we’d be able to take a closer look at it. If you don’t want to share it here, feel free to open a support ticket with the .fmx attached and I’ll keep an eye out for it. Please let me know if you have any questions!
evoteck
  • March 4, 2025
@saraatsafe  I have open a support ticket.
saraatsafe
  • March 5, 2025
