Convert IFC to file geodb using arcpy
  • February 20, 2025
  • 36 views
rmpayaby
I'm fairly new to IFC and the PythonCaller transformer.
I have an IFCReader and want to use PythonCaller to convert an IFC file into an Esri file geodatabase using arcpy, allowing me to upload a scene layer package. Any tips on how to get started?
jobvdnoort
Forum|alt.badge.img+10
  • February 21, 2025
What I most of the time do is read the IFC with a featurereader.
Then with the Geometryfilter filter out the Null.
and write the rest of the geometry it to a GDB as a multipatch.
This will read perfectly in arcgis
rmpayaby
  • February 27, 2025
Just another question. When I add a FeatureReader, where should I connect it to the Geometryfilter? Should it be on the Schema or should I connect all of them?:
jobvdnoort
  • February 27, 2025
Hi I put my output ports on:
in your case you can just connect 1 port to the geometryfilter.
