I have a large number of spatial tables, each potentially having dozens of date fields. I need to check the dates in each of these fields to check they are greater than a certain data (01/01/1900?). These tables are being taken from Oracle and uploaded to AGOL. If there are any dodgy dates, it appears to break AGOL and no spatial data appears for the whole dataset!
Is there a way to automatically select fields with a type of date or date time and check validate each row for each date field is above that date? That way I could investigate and correct before the data is transferred. There doesnt seem to be any kind of filter for attribute type.
Once I have done this, I will need to do something similar with varchar fields as AGOL doesnt like certain characters.
Many thanks
