Hello everyone,
I have a question regarding the fme_feature_type. I encountered a problem in my workspace regarding the SchemaMapper which (after working properly before) gave me the following error:
SchemaMapper_Mapper (SchemaMappingFactory): A required column was not found in the table. Row fme_feature_type will be skipped.
After doing some testing I realized the attribute fme_feature_type was <missing> across the board in this particular conversion which I believe is required for the SchemaMapper to work.
I’m somewhat stumped because sometimes the workspace functions properly and the attribute has proper entries. I noticed especially with larger datasets that fme_feature_type just goes missing between transformers. Some culprints that I found were for example the SubstringExtractor and the AttributeKeeper. The data goes in with fme_feature_type properly filled and comes out with the data missing.
I don’t think this is expected behaviour but maybe someone can shine some light on what might be happening here.
Thanks all.
