Copy files from one server to another.
  • January 17, 2025
  • 51 views
poonam21
Forum|alt.badge.img+7
Hello Forum,
I am currently working on a task that involves copying files from a source server (Server 1) to a destination server (Server 2). I am new to FME and am unsure how to approach this.
Could this process be achieved using an FME transformer, or would it require writing a Python script? I would greatly appreciate any guidance or suggestions on where to begin.
Thank you in advance for your support!
One way to do this is to use the FileCopyWriter.
A different approach would be to use a SystemCaller with dos commands like
copy C:\temp\a\test.txt C:\temp\b\
poonam21
  • January 17, 2025
Hey ​@nielsgerrits
Thanks for the reply.
Using FileCopyWriter, would that be possible for different servers?
UNC paths are supported, so as long FME can reach these locations via UNC paths, yes.
