Coordinate system is not setting for Revit to GIS conversion
  • January 10, 2025
  • 59 views
nea
Forum|alt.badge.img+9
I’m converting 135 Revit models to GIS but the coordinate system is not setting (location is Philidelphia but data is appearing in Ohio).  I’ve tried setting the coordinate system (NAD 83, Pennsylvania state plane south, US foot) in the writer and using CoordinateSystemSetter.  Individual models appear properly in ArcGIS Pro.  I’m really baffled by this one; probably something simple I’m missing.
Best answer by nea
Thanks, but this does not work.  Data should be coming at Philidelphia Airport, but it is coming in at central VA,
emmaatsafe
  • January 16, 2025
Hi ​@nea
Would you be able to try setting the Coordinate System to LL84 in CoordinateSystemSetter then connect it to a Reprojector and set the Destination Coordinate System to EPSG: 2272
Emma
nea
  • January 23, 2025
saraatsafe
  • January 28, 2025
Hi ​@nea, a couple of questions & things to try:
- Was there already a coordinate system in your Revit file?
- In your Revit reader parameters, what is your “Revit Coordinate System to Read” set to? It might be worth trying out the Georeferenced option.
- Would you be able to run your workspace with feature caching enabled and then checking on the Coordinate System line item in your Feature Information Window? We can see if it gets set at all or if there’s maybe some other issue with the data or transformer.
