Using SharepointOnlineConnector with OneNote
  • December 20, 2024
  • 49 views
_jacques_
Forum|alt.badge.img+14
Quick Question.. I’m trying to use the SharepointOnlineConnector transformer to access/download contents in my OneNote, but no luck so far and now I’m questioning if this is even possible?
I can’t find any examples or information of this anywhere.
Best answer by jobvdnoort
Hi _Jacques,
I assume you mean Onedrive?
When you use the sharepoitn online connector, you connect to Sharepoint Online.
To read files from your own personal Onedrive you can use the featurereade for this :)
jobvdnoort
Forum|alt.badge.img+10
  • December 20, 2024
Hi _Jacques,
_jacques_
  • December 20, 2024
Thanks, ​@jobvdnoort! :- )
