Unexpected result from Area on Area Overlayer
  • December 10, 2024
  • 37 views
rob_m_esriuk
We have two different buffer results from the same road network and I’m doing some work on identifying what is different
These are large multipart polygons and I wanted to chop them up to give common parts (overlay > 1) and individual parts. In the picture I want to separate the red hatched bit and the solid blue bits from  the combined data. Running the area on area overlayer with no grouping but creating a list of parts results in…
Where the orange hatching has created a fill in on the closed triangle  and the roundabout. This is not what I was expecting but I cannot find a setting on the transformer to avoid this.
Help!!!!
Rob
mholemans
  • December 10, 2024
For the moment I don’t know the root cause for this behavior. A possible solution/workaround can be to use the Intersector instead of the areaOnAreaOverlayer?
Do you get the same results?
liamfez
Forum|alt.badge.img+34
  • December 10, 2024
Could also try the Clipper
