I have created a gdb with 2 feature classes, strings and points. But it only works the first time. Every time I make changes to the model and run it again I get errors. I have tried changing every setting but nothing helps. The only thing I can do is create a new gdb every time but that is not the intention.
I usually use the Insert and drop and create settings
