Hi all,
i've got a strage error. I have about 30 ArcGIS Online readers that i want to read, update and write back to ArcGIS Online. Now, the update part with the Changedetector workes fine. (Dont look at the mess ;).
The problem:
When i run the workspace, it gets all the 41K features that are in there. The other ones are skipped because it is not found. This works as it should work.
After that it tries to search in groups accessible to the user, and then it says "error running translation”.
Does anyone know how to fix this? I have attached the log file and the workspace.
Thanks in advance!
