Unable to connect to Enterprise Portal: unable to retrieve access tokens
  • November 11, 2024
  • 178 views
marronm
FME Desktop version: FME 2021.2
I was trying to follow this article on How to Create an ArcGIS Enterprise Portal Web Connection (OAuth 2.0)
(https://support.safe.com/hc/en-us/articles/25407772142733-How-to-Create-an-ArcGIS-Enterprise-Portal-Web-Connection-OAuth-2-0)
It was going well until I tried to 'test' before moving on to Step 3 and I got the following error (see also attached):
Unable to Retrieve access token
Request to update access token failed. HTTP Error HTTP/1.1 401 Unauthorized
Does anyone know what this error in referring to?
j.botterill
Forum|alt.badge.img+39
  • November 12, 2024
Hi marronm, were you able to save the web service, then go to step 3 and create a web connection using that service. Upon clicking authenticate does it throw the same error as the ‘test’
marronm
  • November 12, 2024
Hi j.botterill, yes I can save the web service but when I move on to the next step and click ‘authenticate’, the same error appears.
jkenney
Participant
  • Participant
  • November 25, 2024
Same issue - was this resolved?
