FME Workspace APP - Markdown URL / Link using Target Blank
  • October 28, 2024
  • 5 replies
  • 102 views
sameer
Forum|alt.badge.img+16
Hello
I have a Workspace App in dev phase.
Since I cannot embed a HTML page by design or make use of dynamic user parameters to retrieve an event ID for now,  I went with the idea of using a URL / Link within the description box, (Markdown style).
URL points to SP Online
I’d like to implement target=”blank”.
[link](url){:target="_blank"} (Kramdown)
Is this possible?
Sameer
Best answer by siennaatsafe
Hi @hkingsbury and @sameer,
I checked in with our development team regarding this.
We use the Marked library to render our markdown: https://marked.js.org/
The team mentioned that we intentionally strip tags like this to mitigate a vulnerability outlined here: https://developer.chrome.com/docs/lighthouse/best-practices/external-anchors-use-rel-noopener.
Because of this, it appears that enabling this functionality isn’t possible at the moment.
Forum|alt.badge.img+53
  • October 28, 2024
It appears that the markdown engine FME Flow is using doesn’t support that, it also strips the target from standard HTML
<a href="https://google.com" target="_blank">Opens in new tab</a>
I think it would be worth opening an idea to allow for links to be opened in new tabs/windows
https://community.safe.com/ideas
sameer
  • October 29, 2024
I also tried a href as well and it failed.
I’ll submit my request as an idea.
How do I find the version of Markdown FME is running on as I could not locate this information?
  • October 29, 2024
Some one at Safe will be able to find that out - @siennaatsafe?
Just linking your idea as well -
siennaatsafe
Forum|alt.badge.img+11
  • October 30, 2024
sameer
  • October 31, 2024
Hello @siennaatsafe
I understand however, rel="noopener" or rel="noreferrer" would always be added in my code.
This vulnerability has been patched with latest versions of Chromium (version 88+ released Jan 2021). I believe “window.opener” was the culprit.
In my case, I’d use:
<a href="https://www.awebpage.com/" target="_blank" rel="noopener noreferrer">A Web Page</a>
I don’t think this is now a security risk unless the target is unsafe in the first instance.
