FME Workbench and other FME Form software broken by VMWare Tools
sussexpete
Since updating our FME Form host computer with the latest version of VMWare Tools, FME Desktop, FME Data Inspector, and all other FME Form GUI software does not run.
We briefly get a spinner and then nothing. The problem was noted on FME version 2021 but is a problem with all version of FME Form up to the latest version FME(R) 2024.1.3.0 (20240927 - Build 24627 - WIN64).
It is still possible to run Workspaces in batch mode.
The issue seems to be with OpenGL as indicted in the log, below.
I would be interested if others have the same issue and, if so, how the issue can be resolved.
Here is a snip from the log file:
VMWare Tools v12.5.0.24276846
Faulting Module = vm3dgl64.dll
Working Version = 3.5.3.2
Faulting Version = 3.6.0.0
Event Log:
Faulting application name: fmeworkbench.exe, version: 2021.7.41.21614, time stamp: 0x60f7b7a5
Faulting module name: vm3dgl64.dll, version: 3.6.0.0, time stamp: 0x66a16726
Exception code: 0xc0000005
Fault offset: 0x0000000000e3696d
Faulting process id: 0x1bec
Faulting application start time: 0x01db207c31ccd839
Faulting application path: T:\FME20211\fmeworkbench.exe
Faulting module path: C:\WINDOWS\SYSTEM32\vm3dgl64.dll
Report Id: 1644a438-73c1-422f-aa9f-d32e5531661f
Faulting package full name:
Faulting package-relative application ID:
Best answer by jovitaatsafe
Hi Everyone!
We’ve seen a few reports on this where upgrading to VMware Tools 12.5 is causing FME to fail to launch with a faulting module of vm3dgl64.dll.
To summarize, (and thanks to everyone for sharing their workarounds as well as reporting this issue!) some folks have found workarounds by:
  • reverting to VMware Tools 12.4
  • OR defining an environment variable SVGA_ALLOW_LLVMPIPE=0 and running FME in the same instance of the command prompt
On a search for this dll crash, Autodesk Forums (external link) suggests either disabling 3D rendering, or uninstalling SVGA if those may be possible for you.
Please give those a try and let me know how it goes as we investigate this issue.
gtitz
  • October 22, 2024
The same here…
Uninstall VMWare Tools v12.5.0.24276846 and install an older version.
We installed VMware-tools-12.4.0-23259341-x86_64.exe (https://packages.vmware.com/tools/esx/latest/windows/x64/) and it works again.
In our environment, the server is configured to automatically install the latest version of VMWare Tools. We had to disable this option for the affected servers in our vSphere client so that the version we selected (12.4.0-23259341) would not be updated again.
Best regards,
Gerhard
duri
Participant
  • Participant
  • October 23, 2024
Same issue here FME 2023.1 b23619
Event Log:
Faulting application name: fmeworkbench.exe, version: 2023.7.47.23619, time stamp: 0x64e967bc
Faulting process id: 0x3808
Faulting application start time: 0x01db24eff922bdc1
Faulting application path: C:\Program Files\FME\fmeworkbench.exe
Faulting module path: C:\Windows\SYSTEM32\vm3dgl64.dll
Report Id: d5e27c45-69a0-43aa-b24a-7089f162eb56
VMware tools
12.5.0.24276846
anfo
Participant
  • Participant
  • October 23, 2024
Same issue for us. Can no longer start FME Workbench 2023.1.2
Event log:
Faulting application name: fmeworkbench.exe, version: 2023.7.47.23641, time stamp: 0x654ef1d9
Faulting process id: 0x1050
Faulting application start time: 0x01db2516289f1e4e
Faulting application path: C:\Program Files\FME_2023_1_2\fmeworkbench.exe
Report Id: 68ae7abc-d159-41ac-a249-b0f126d34bdc
VMware version 12.5.0.24276846
bfausel
  • October 23, 2024
Same issue with FME version 2022.7.45.22800, time stamp: 0x646d60f8.
Not sure about VMware version
jovitaatsafe
Forum|alt.badge.img+11
  • October 23, 2024
Hi Everyone!
schlomm
  • October 24, 2024
@jovitaatsafe  Thank you for the additional information. Do you have any information on whether the problem is related to the FME or rather VMWare? Depending on which component is causing the problem, we would create a support case with VMWare
jovitaatsafe
Hi @schlomm, I’m not really sure at the moment as we’re still trying to reproduce the behaviour on our side, but it sounds like reports on this crash on vm3dgl64.dll are all occurring on VMware after the update to 12.5.
I think it’d be worth reporting it with VMWare to see if they have any further information. Are any other programs affected for you running on VMware?
schlomm
  • October 24, 2024
Hello @jovitaatsafe ,
The problem is definitely caused by the update to VMWareTool v12.5. The data center has reset the VMWare Tools version to 12.4 for testing purposes and FME can be opened correctly with the older version.
Regarding the question of whether this also occurs with other programs: So far I have not been able to detect this problem with other programs installed on the same host. To test this in more detail, I would need to know which graphics stack FME uses (QT with OpenGL?).
Some additional information I found:
At the moment I can't tell if the problem is caused by a faulty vm3dgl64.dll driver or e.g. an outdated usage in FME.
jovitaatsafe
Thanks @schlomm  for sharing your findings! Yes, I believe you’re right on QT and OpenGL.
jovitaatsafe
Bit of an update: Some folks may be aware that we’ve filed a report for development tracked internally as (FMEFORM-32248). The team had a chance to review it and we believe that this may be an issue on VMware’s side as we haven’t made any changes on ours.
We’re waiting to see if VMware will put out anything in their future updates, so please let us know if there’s any update if you have a support case with Broadcom/VMware.
We’re not currently planning to put out any patch, but we’d be happy to work with you further if you’re not able to find a solution, so please let us know!
nick.xu
  • November 18, 2024
I saw the same issue for FME desktop on VMs. We have FME servers and please let us know if the version of tools will affect FME servers as well.
By the way, we also notice that the 12.5 tools will affect arcgis server print services. We have to downgrade tools to 12.4 to let print service works.
Thanks!
Nick
redgeographics
Forum|alt.badge.img+49
Is this problem still occurring with FME 2024.2? ​@jovitaatsafe do you have an update on this?
jovitaatsafe
nick.xu wrote:
Thanks!
Nick
Hi ​@nick.xu, I’m not aware of any reports with VMware Tools 12.5 affecting FME Server/Flow, so please do let us know if you run into any issues.
Good to know that VMware Tools 12.5 is also affecting ArcGIS Server, thanks for sharing that!
jovitaatsafe
Hi ​@redgeographics,
I just installed FME 2024.2 on VMware with VMware Tools 12.5 and I can confirm there’s no change; FME can’t seem to launch on VMware Tools v12.5.
Some of the previous reports we were getting ranged from FME 2019.x through to 2024.x so the FME version didn’t seem to matter.
gowthamvino
Participant
  • Participant
  • November 26, 2024
Windows Operating System :
Click on start --> Search and Open --> Edit the system Environment variables --> Environment Variables
--> System Variable --> New -->  Update below variable and restart --> Open FME to verify
Variable name : SVGA_ALLOW_LLVMPIPE
Variable Value : 0
lorinda
  • December 5, 2024
I’ll add us to the mix, we got hit over the Thanksgiving weekend, evidently our updates were a bit later.  But it hit my FME VM for FORM, not sure about FLOW yet, it opens, but we are in the process of building out new servers, so no automations or anything set up yet.  But also got both of our ArcGIS Servers with the print breakage.  I will try the variable reset to see if it will work.
Lorinda
amarsden
Participant
  • Participant
  • January 6, 2025
Does anyone know it Esri have been informed of this issue?  We just hit the Print Services issue after updating the Client tools.  We can roll back, but need to know who is looking at the issue to prevent it happening again if we up date the tools.
Did anyone workout if it is an issue with the DLL or how the DLL is being used?
Edit - see Error: ArcGIS Server Print Service Crash When VMWare 12.5 is Installed
colin_a
Participant
  • Participant
  • January 7, 2025
Variable Value : 0
This worked for me!
redgeographics
Is there a permanent fix for this known yet? Any word from VMWare themselves?
hakansweden
Participant
  • Participant
  • March 24, 2025
@redgeographics
I had this crash issue with my VPN software https://www.ovpn.com/
The support team at OVPN found out about the SVGA_ALLOW_LLVMPIPE environment variable mentioned earlier in this thread, and it works for me.
They found this official Broadcom info:
https://knowledge.broadcom.com/external/article/383994/applications-using-vmware-tools-125-is-c.html
I’d say their article is a bit off though, probably copy/pasted from something old, since the instructions says to edit the PATH variable..?
Creating a new variable called SVGA_ALLOW_LLVMPIPE with the value 0 is what is needed.
There’s also an older article about the same underlying LLVMPIPE issue:
https://knowledge.broadcom.com/external/article/331541/opengl-dll-is-not-unloaded-on-applicatio.html
It says to disable the use of llvmpipe by adding this virtual machine config option to the VM's VMX file: guestinfo.svga.disableLLVMPipe=TRUE
(I’m not an FME user; I searched SVGA_ALLOW_LLVMPIPE to find out more, and just wanted to add the Broadcom article here.)
nia.colebrooke
Hello, I have an update on this thread.
I tested Workbench on a server with VMWare Tools 12.5.1 today and could successfully open it. It looks like 12.5.1 should work with FME Form based on my experience and this resolved issue mentioned in the 12.5.1 release notes:
In VMware Tools 12.5.0, some OpenGL applications experience memory corruption issues, leading to unexpected failures.
