Error connecting to Oracle-DB, but only on FME Form (FME Flow ok)
vki
Forum|alt.badge.img+7
We recently updated to 2024.1 (FME Form and Flow).
We have some jobs, that run daily on FME Flow, that read features from an Oracle-db and write to a PostGIS-DB.
I downloaded one of the workspaces to FME Form to change something. But in FMEForm I cannot connect to the Oracel-DB anymore. I get this error:
Error connecting to Oracle database: message was `OCI_INVALID_HANDLE'. (serverType=`ORACLE_NONSPATIAL', serverName=`xy', userName=`xy', password=`***', dbname=`')
I uploaded the workspace again to FME Flow and there it ran successfully.
Any ideas, what could be the problem? Thanks in advance.
Vera
frro
Forum|alt.badge.img+13
  • October 9, 2024
There has been a change in connection storage encryption in FME Form 2024.0.
This may cause problems with your connections after upgrading from older versions of FME Form and Desktop. Have a look at this support article:
Changes to Connection Storage in FME Form 2024 – FME Support Center (safe.com)
This security enhancement, and its side effects, probably could have been more advertised in the community.
Hope this helps!
vki
  • October 21, 2024
It was obviously a problem on the database side. Everything is working again now.
Thanks.
