Deployment automation of Github assets using FME Flow upon Github merge events
bo
Forum|alt.badge.img+10
Our team uses GitHub, VS Code and FME Workbench for our data engineering projects with good results. Now we want to leverage FME Flow to automate the deployment of FME assets upon a GitHub merge to the Staging and Production environments.
I would appreciate any suggestions or experiences in this regard.
Best answer by hkingsbury
I don’t have a specific answer (it is in fact something I’d like to explore more - interested in responses to your question) but here are a couple of documents and presentations that might help point you in the right direction
https://support.safe.com/hc/en-us/articles/25407510327437-Getting-Started-With-CI-CD-DevOps
https://fme.safe.com/webinars/mastering-devops-driven-data-integration-with-fme/
https://fme.safe.com/presentations/deploy-fme-integration-azure-pipelines-10-minutes/
https://support.safe.com/hc/en-us/articles/25407730429453-Workbench-Git-Integration-from-the-Command-Line
Forum|alt.badge.img+53
  • October 7, 2024
bo
  • October 12, 2024
Thank you @hkingsbury for your response with summary of links to FME in context of DevOps.
