HTTP call syntax to retrieve OSM data
conch
Hi
I’ve been constructing http calls to download OSM data to a .OSM file, then reading the downloaded .OSM file via a FeatureReader to generate specific outputs (yes, I know there are downloadable OSM transformers but they don’t do what’s required here).
The specific problem I’m having is, not returning way or relation items into the downloaded file (if this is possible).
Looking for assistance regarding the http call syntax. Below is what I’ve tried but still only returning point features (same results for both).
https://overpass-api.de/api/interpreter?data=[bbox];node[building];out;way[building];out;relation[building];out;&bbox=@Value(_xmin),@Value(_ymin),@Value(_xmax),@Value(_ymax)
https://overpass-api.de/api/interpreter?data=[bbox];nwr[building];out;&bbox=@Value(_xmin),@Value(_ymin),@Value(_xmax),@Value(_ymax)
AliAtSafe
Forum|alt.badge.img+22
  • October 7, 2024
Hi, @conch!
Thanks for posting on the Safe Community Forums! To best help you out, could you give more details about what you meant by "not returning way or relation items into the downloaded file (if this is possible)?" Also, could share a sample screenshot of the HTTPCaller and the syntax you are using (if possible).
Thank you!
ctredinnick
Forum|alt.badge.img+18
  • October 8, 2024
I’ve found LLM’s to be good ways to craft these types of queries and explain the syntax.
This is one I’ve used before for specific types of buildings, looking for multipolygon relations only. You should be able to remove the filter on building type to get all if that’s what you’re wanting.
[timeout:25][bbox:-48,166,-33, 180];
  way["building"~"supermarket|warehouse"];
  relation["building"~"supermarket|warehouse"]["type"="multipolygon"];
(._;>;);
out;
With an HTTPCaller, post that to http://overpass-api.de/api/interpreter
conch
  • October 8, 2024
Hi @ctredinnick
thanks for that code snippet. It does work when turned into a URL based query but didn’t achieve exactly what was required. It did however lead me to some extra information I found on the Overpass API page that led to a modification of the query I was using - just needed to add the “area[building];” statement into the above queries.
Thanks for your help!
