FME FLOW and FME FORM compatibility
  • August 20, 2024
  • 126 views
mathieu_ctg
I’ve a FME FLOW in 2023.2.1. Which version of FME FORM 2023.X.X we need to use ?
2023.2.1 or 2023.2.4 (the last in 2023.X.X)
Thank for your feedback
donalmateer
  • August 21, 2024
Hi @mathieu_ctg,
Thank you for the question!
Publishing is supported if the year and major version match and the version of FME Form is the same or older than FME Flow.
The following article speaks about FME Versions and Workspace Compatibility.
If you need any further assistance please don’t hesitate to reach out!
Thank you,
Donal.
mathieu_ctg
  • August 21, 2024
