Use ODATA Reader to read nested complex types (arrays)
_fabian_
I’m trying to retrieve data from a nested JSON response of an ODATA Feed.
For testing, I try to access the “Emails” property of this ODATA example service: https://services.odata.org/V4/(S(hg4u5ox0x0r2rjva5qwwra05))/TripPinServiceRW/People
The JSON structure is as follows:
    "@odata.id": "http://services.odata.org/V4/(S(hg4u5ox0x0r2rjva5qwwra05))/TripPinServiceRW/People('russellwhyte')",
    "@odata.etag": "W/\"08DC9753B5381A6D\"",
    "@odata.editLink": "http://services.odata.org/V4/(S(hg4u5ox0x0r2rjva5qwwra05))/TripPinServiceRW/People('russellwhyte')",
    "UserName": "russellwhyte",
    "FirstName": "Russell",
    "LastName": "Whyte",
    "Emails": [
        "Russell@example.com",
        "Russell@contoso.com"
    "AddressInfo": [
            "Address": "187 Suffolk Ln.",
            "City": {
                "CountryRegion": "United States",
                "Name": "Boise",
                "Region": "ID"
    "Gender": "Male",
    "Concurrency": 638551632958200400
The “Emails” property is a complex type property, which should be able to be read by the readers documentation.
Each entry represents a structured record with a key that has a list of properties of primitive or complex types.
But when using the ODATA reader, only the simple properties get returned:
Is there any possibility to read nested properties (JSON objects/arrays) or do I have to resort to using a HTTPCaller?
Best answer by debbiatsafe
Hello @_fabian_
It appears the OData reader does not currently support reading Complex Type properties within a Complex Type. FMEENGINE-40129 tracks improving support for OData version 4, which should add support for reading nested complex type properties.
You may need to read the OData feed with an HTTPCaller and parse the JSON response with JSON transformers. Attached is a simple workspace demonstrating this approach, and I hope it helps.
debbiatsafe
Forum|alt.badge.img+20
  • June 28, 2024
Hello @_fabian_
_fabian_
  • July 1, 2024
debbiatsafe wrote:
Hello @_fabian_
That’s a pity 😔 Looking forward to the improved reader! Thanks for the quick reply and clarifying the current limitations.
