I have address data in CSV format. there are address number ranges, street address from number and street address to number, and sequence code (1 for odd, 2 for even, and 3 for consecutive).
I need to expand these ranges into individual addresses based on sequence code and write them in a new CSV.
Any guidance for doing this task in FME would be appreciated. Thanks
Expand address ranges in FME
Best answer by ev_robin
If I understand your question correctly, you would like to create a CSV entry for every address in the range specified by each row. A cloner might be a simple way to do that. Some attribute managers can handle populating the fields. I’ve attached a workspace that might help as a sample.
Start:
from_address_num to_address_num sequence street city state zip
1 9 1 baker st. new york ny 00000
2 6 2 baker st. new york ny 00000
101 109 3 broadway st. new york ny 00000
End:
current_address from_address_num to_address_num sequence street city state zip
1 1 9 1 baker st. new york ny 00000
3 1 9 1 baker st. new york ny 00000
5 1 9 1 baker st. new york ny 00000
7 1 9 1 baker st. new york ny 00000
9 1 9 1 baker st. new york ny 00000
2 2 6 2 baker st. new york ny 00000
4 2 6 2 baker st. new york ny 00000
6 2 6 2 baker st. new york ny 00000
101 101 109 3 broadway st. new york ny 00000
102 101 109 3 broadway st. new york ny 00000
103 101 109 3 broadway st. new york ny 00000
104 101 109 3 broadway st. new york ny 00000
105 101 109 3 broadway st. new york ny 00000
106 101 109 3 broadway st. new york ny 00000
107 101 109 3 broadway st. new york ny 00000
108 101 109 3 broadway st. new york ny 00000
109 101 109 3 broadway st. new york ny 00000
