Hi.
I’m using the snipper transformer to extract portions of a line at specific values from the attribute table.
I set these parameters for the transformer.
The problem that I noticed is that the program considers the first vertex of the line as 0 and the last one as the maximum, and the snipper will split between these two values.
Is there a method to define the start value using another value, not 0? I would like to start from 4.21 km.
Thanks.
