kml placemark name as output dwg layer name
alanaliberti
Hello all
I’m trying to achieve the above, so far I’m struggling on how to find out the KML reader ‘placemark name’ property, to write it as a DWG layer name.
Could anyone point me out on how to do that? Thanks
danilo_fme
Forum|alt.badge.img+45
  • June 17, 2024
Hi @alanaliberti
Please, could you share the kml file?
Thanks in Advance,
Danilo
alanaliberti
  • June 17, 2024
Sure thing, there you go Danilo
Thank you
liamfez
Forum|alt.badge.img+34
  • June 18, 2024
If you look in the Format Attributes section of the reader, there are a lot of kml attributes that can be exposed, including kml_name which may be the one you are looking for.
alanaliberti
  • June 18, 2024
Yes, this is the one I’m looking into:
but then I get this error when I run it:
And then nothing is converted. if I use a static layer name it goes smoothly
thanks for your help
liamfez
  • June 18, 2024
That Unexpected Input warning normally points to an issue with the Reader, not the writer. It is saying that the file you are reading in has 9 features that could be read but were not because they are in the feature types StyleMap and Style, not Placemarks. If you wanted to get those features you could try updating the reader and its feature types to include those or try adding a new kml reader that is Single Merged Feature Type instead of Individual Feature Types. If you were expecting placemark features, then there could be another issue.
