Not able to update a field in a FGDB using FeatureWriter
nea
Forum|alt.badge.img+9
II read from a FGDB do some processing then I want to write back (update) to a field in the same FGDB.  I have a FeatureHolder immediately  after reading the FGDB to force complete reading before writing.  The Where clause  make sure I only update records with matching PremiseIDs (original source data and stream data).  I only want to update one field but I don’t see how to specify that field in the FeatureWriter.  In a AttributeManager before the writer I remove all other attributes than the one I want written.  Not working.
Best answer by frro
I believe it’s better to use OBJECTID under Columns for updates.
Only let through the update features and just keep the OBJECTID and the Premise_ID attributes and you should be fine.
This works for me:
Cheers!
frro
Forum|alt.badge.img+14
  • May 20, 2024
This works for me:
Cheers!
nea
  • May 21, 2024
Thank you so much.  This worked great!!   This makes so much sense to use the OBJECTID field.  So with this update option there is no way to specify a field to update.  In my case It is OK.  I’m just use to the SQL type Update which allows for specifying a field.
Thanks again.
