ArcGIS Feature Service Reader to Excel Writer missing feature tables
  • May 8, 2024
  • 20 views
michael_v307
Participant
I had a FME scenario running to read the feature service and related tables and write to an excel file. I have the excel writer setup to “Fanout” the dataset which used to drop each table from the feature service into its own sheet within excel.
I went back to run the FME scenario and when I check the excel outputs some of the tables are missing. Prior to running the scenario I check to make sure all the tables are checked and that the reader is seeing all of the tables, which it is. I check “select all” and run the scenario but when I check excel I get 6 of 9 tables. I have double check every setting and even started a new FME template and recreated the reader/writer but I still don’t get all the tables in the excel output.
Can anyone help me out?
Thank you
Hard to say without more info.
Any warnings or errors in the log?
Do all related tables in the feature service have records? If no records, no worksheet is created.
