Need Help with Batch Processing Using Workspace Runner
larue
I have been trying to set up a batch process to create dwg files, adding a template based on the respective input file.  I have tried to follow the advice from the links below, but am missing something or what I am doing isn’t quite the same.  At any rate, my workspace fails after trying numerous different configurations.
Published Parameters
Batch processing
I have attached the two Workspaces.  The goal is to apply a CAD template to it’s respective output file, with the inputs controlled by the WorkspaceRunner parameters.
The Workspace that outputs dwgs takes inputs from three sources:  Two different folders of CAD files (one of which also happens to be same as the template but used for a different purpose), and a spreadsheet .  Any insight is appreciated.
Thanks.
