MongoDB writer with nested documents
txalaparta
I am working with MongoDB trying to upsert nested MongoDB documents. The JSON format would be something like:
“name”: “XXX”,
“tables” : [
“name”: “XXXX”,
“num_rows” : 3423,
“fields”: [
        {“name”: “XXX”, “type”: “yyyy”} , ….
I have no problems when I use a JSON string attribute inserting a new document with Document Source”: Json Attribute” and Insert operation.
But, I do need to UPDATE existing features.
In this case, the nested dcouments (tables in the json above) are created as plain strings.  Which is a real inconvenience in my use-case.
“name”: “XXX”,
“tables” : [ “{“name”: “XXXX”,“num_rows” : 3423,“fields”: [         {“name”: “XXX”, “type”: “yyyy”} , ….     ]} “ , ….
Valid datatypes do not currently include arrays (of objects)
 Is there any alternative or workarounds?
liamfez
Forum|alt.badge.img+34
  • May 2, 2024
Out of curiosity, what version of FME are you working with? I have been running into similar problems, I will link my post in another comment where I reference a couple old posts relating to mongo arrays. I too have been dealing with the limitation of only using RAW JSON on Insert.
liamfez
  • May 2, 2024
