Splitting a GIS table into multiple tables for each object or an attribute related to the object
ruth_h
Hi there, I have a mapinfo table and I would like to split the table into multiple tables - one for each object.  Also one for particular attribute related to the object - eg libary and community centre.  And then write these out and save as multiple tables.  I would be grateful for some advice. Many thanks
becchr
Forum|alt.badge.img+25
  • April 12, 2024
hi, the question is not very clear, but maybe fanout is all you need?
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/fanout_about.htm
ruth_h
  • April 12, 2024
Thank you!  That is exactly what I needed.
