Is Azure Communication Services (ACS) supported in FME?
As far as I know, the Azure Communication Services are based on API REST. Is that right?
If FME doesn’t support natively the ACS, you can always use the API inside FME.
33 votes
21 votes
20 votes
19 votes
15 votes
10 votes
9 votes
8 votes
Already have an account? Login
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
Sorry, our virus scanner detected that this file isn't safe to download.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
