Setting up FME server for High capacity
  • February 5, 2014
  • 4 views
HI,
 I have
    machine A : webservices/core running
   machine B : Engine running
The services on both machine are running under the same domain account. Now, the machine A starts fine, but the FME engine on machine B doesn't start ( it would start and stop again ) .
Basically, i am not able to connect the FME engines to core.
-varun
Best answer by kathyross
This would be due to an environmental setup problem and would be best assisted via a remote session or the like.
I would recommend either stepping through the Administration Guide once more or  logging a support case.
More information on the error may be logged under Event Viewer or in the Logs directory and may be able to further assist you in locating the cause.
Forum|alt.badge.img+4
  • February 21, 2014
