Scheduled Retry on FME-Server
  • Apr 29, 2020 9:22 AM UTC
  • 138 views
I have a workspace which fetches data from a webservice, creates a new output and then submits said output to an e-mail recipient.
Sometimes fetching the date throught the HTTPCaller fails due to the source being unavailable. Since this is an issue with a proxy which I cannot fix, I need my workspace to restart if fetching the data has failed. However, immediately retrying doesn't work because if the source is unavailable, it usually stays this way for a few minutes.
I would therefore like my workspace to run and retry after 15 minutes if fetching the data fails.
So far, I can think of the following solutions:
  • encapsulate the httpCaller in a custom transformer and use a loop if no data is returned. Works ok but blocks one of the server-engines as long as the data source cannot be reached. Also the delay before the next rety needs to be set within the workspace.
  • use a ServerJobSubmitter that runs the same workspace again - might lead to an endless loop. Again delay has to be set within the workspace and engine is blocked.
  • if fetching the data fails, create a one-time-schedule throught the REST API which runs the job again.
So far, the last option sounds best to me, but I feel that there should be a more elegant way of doing this. What am I missing?
itsmatt
Forum|alt.badge.img+48
  • Apr 29, 2020 12:00 PM UTC
if fetching the data fails, create a one-time-schedule through the REST API which runs the job again.
This is a cool idea for this problem - but you are right there must be a better way. Seems like there needs to be a "wait" function in the Automations list. That would help you.
In FME 2020 there is a HTTP call as an automation option. Perhaps there is some way you can use that as an advantage. Ping the service at regular intervals to see if it's active?
  • Apr 29, 2020 8:28 PM UTC
I'll check out the http call within automations as soon as we have upgraded to the 2020 version. I just seems odd to me, that I cannot find a nicer way to do this.
A "wait" option in automations might be nice for other use cases too.
