REST token with Active Directory Securioty
  • January 10, 2014
  • 10 views
Hello,
I have used the sample REST C# code supplied by Safe to create a simple application. The sample code provided can be located here:
http://docs.safe.com/fme/html/FME_Server_Documentation/Content/REST/FMEServerRestAPIdemo.cs
We have two FME Servers here, one in a test environment, and another for production.
I have written my code against the test server, which uses standard security, using user and password managed by FME Server. Everything works fine.
However, when I use my code against the second server, which is secured by the Active Directory, I always get error 401, access denied.
Is there anyone out there that has used the REST API with Active Directory security?
Here is an example of the code I use to fetch a token:
        private string GetFmeServerToken()
            string fmeTokenUrl = this.Serveur + "/fmetoken/service/generate";
            NameValueCollection parameters = new NameValueCollection();
            parameters["user"] = ; "user"; // tried with and without domain name
            parameters["password"] = "password";
            parameters["expiration"] = "2";
            parameters["timeframe"] = "minute";
            byte[] reponseBytes;
            using (WebClient client = new WebClient())
                if (CustomSetting.FmeImpersonationUtilisateur)
                    client.UseDefaultCredentials = false;
                    client.Credentials = new NetworkCredential("user", "password", "domaine");
                reponseBytes = client.UploadValues(fmeTokenUrl, "POST", parameters);
            return Encoding.UTF8.GetString(reponseBytes);
Now, to make matters worst, I need to authenticate with a different user account that the one running my application, meaning I need to impersonate a different account.
This code should work, should it not? I tried to not provide the user/password in the named values, which gave me error 400 bad request. I tried without the impersonate code, providing error 401 access denied.
No matter what I do, or what I permutated in my code, I can not get anything to work.
Thank you
Jeff
  • January 13, 2014
sounds like it might be a configuration error on the AD side of things. have you looked in the FME Server logs?
David
fmelizard
Forum|alt.badge.img+18
  • January 29, 2014
Also consider the fmetoken service...
On your production environment can you access <fme url>/fmetoken? Can you log in and create a token with an AD user?
  • January 29, 2014
Issue resolved.
First you do not have to impersonate the user, simply feeding the credential into the post query is enough.
Jeff
