Please help integrate FME and ArcGIS.
  • Aug 14, 2020 11:12 PM UTC
  • 80 views
ScreenShot12I have FME Desktop 2017 and ArcGIS 10.6.1 installed. I followed all the steps in the FME Integration Console, but I didn't get the desired result. What is the problem?
Thank!
Best answer by rjcragg
Hello. The issue is that you have a 64-bit FME installed, but ArcGIS is 32-bit. If you install a 32-bit FME, then you will see ArcGIS listed in the FME Integration Console.
rjcragg
  • Aug 14, 2020 11:41 PM UTC
andreaatsafe
Forum|alt.badge.img+17
Hi @tikhpetr​ ,
Along with using a 32-bit version of FME, you will also need the following to be able to extend FME with ArcGIS 10.6.1:
  • FME 2017.1.1 or newer (you can find previous installers here)
  • an Esri edition license or higher
For more details, this article has information about what version of FME is needed for your version of ArcGIS.
