how to call curl command in HTTPCaller
nag
Hello Team,
Can somebody help me to call following curl command through HTTPCaller?
curl --user <consumer_key>:<consumer_secret>         -X POST https://identity.trimble.com/token
        -H 'Content-Type: application/x-www-form-urlencoded'         -d 'grant_type=password&username=<user_email>&password=<password>&scope=openid&tenantDomain=trimble.com
If possible can provide one example, Following command we are going to use to generate Token Id.
Thanks..
Best answer by nielsgerrits
Can not check exactly because we don't have the username, password and redirect_uri, but it should work with something like this. I think it will work when you replace username, password and redirect_uri with real data.
httpcaller2019.fmwt
nielsgerrits
Forum|alt.badge.img+54
  • June 28, 2019
httpcaller2019.fmwt
jkr_wrk
Forum|alt.badge.img+29
  • June 28, 2019
httpcaller2019.fmwt
I expect that "Use Authentication" must be off. The website expects the Username and Password as Multipart / Form Data (Based on the fact that it is set with the -d parameter in the CURL.)
As body you have to set Upload Data to Multipart / Form Data.
And all the parameters after the -d are Name Value just like Niels set the Query String Parameters. And the Type is set to String Upload.
I expect the -H parameter 'Content-Type: application/x-www-form-urlencoded' to be set by FME when you choose the Upload Data to be Form Data. If this is not the case you have to set this manualy within the Headers settings.
nag
  • June 28, 2019
It worked for me. Thank you.
