ftpcaller download file higher level direcotory
rudy_v
Hi All,
I can download a file using the ftpcaller, but cannot work out if possible to download when the file is on higher level directory
ftp://172.30.227.2/../gisgroup/test.zip
Is this possible?
Best answer by david_r
Is this the URL you're using? If so, it will proably not work since you're trying to go on level up relative to the root.
This ought to work:
ftp://172.30.227.2/gisgroup/../test.zip
Which would be the equivalent to:
ftp://172.30.227.2/test.zip
  • October 10, 2016
This ought to work:
rudy_v
  • November 7, 2016
This ought to work:
ftp://172.30.227.2/../gisgroup/lab2prod/test.zip works but the ftpcaller don't seems to like it
getting HTTP/FTP transfer error'Access denied to remote resource'
rudy_v
  • November 10, 2016
ftp://172.30.227.2/../gisgroup/lab2prod/test.zip works when go to it direct
