FME Server Rest API Python Data Upload/Download
  • January 24, 2019
  • 5 replies
  • 125 views
cwarren
I am still learning FME Server's REST API and was wondering if it is possible to use python to upload a file to FME Server to be processed and receive the data download file? I am going through the REST API training and working with code that is available on the developer playground,[https://playground.fmeserver.com/python-request/] but could use some guidance on how to properly upload a file to FME Server to run the workspace and retrieve the download. For my test purposes, I'm just using txt files. I would like to upload a text file, then retrieve the output text file data download zip. I'm not familiar with Javascript, so I was wanting to integrate this into my Python application.
  • January 25, 2019
Yes, it's definitely possible.
There are some sample applications that showcases this on the FME Server Playground, e.g.
https://playground.fmeserver.com/javascript/server-uploads/upload-file-in-session/
cwarren
  • January 25, 2019
Hi @david_r, I've looked at the javascript examples in the playground and was just curious if this was possible with python. I have successfully ran a workspace with python (using the python template code from the developer playground), but I'm looking at a way to upload/download with python.
  • January 25, 2019
Yes, it's definitely possible with Python as well. I would recommend using the excellent requests module, it makes things a lot easier than the standard library.
@guy_lafleur has also published Python code on github that implements parts of the REST API in Python, which can be either used as-is or as inspiration for creating something on your own:
https://knowledge.safe.com/questions/81237/python-fme-server-rest-api-wrapper.html
cwarren
  • January 25, 2019
Thanks @david_r, I will look into that.
xtian79
  • September 23, 2019
In the current version of FME Server you can use:
POST /repositories/< repository >/items/< item >/resources
