FME Server : FTP trigger with FTPES does not work
I'm using the FTP trigger in FME server with a FTPES site but it doesn't work. It does work in a FTPCaller Transformer.
the logs in FME UI are not very useful (the logs here are shown in reversed timestamps):
In the logs here : tail -f /opt/fmeserver/resources/logs/core/current/publishers/ftpwatch.log
there are some clues but I can't figure out why this is happening on server and not in the transformer :
it.sauronsoftware.ftp4j.FTPException [code=503, message= SECURITY_FTPES cannot be applied: the server refused both AUTH TLS and AUTH SSL commands]
at it.sauronsoftware.ftp4j.FTPClient.login(FTPClient.java:1229)
at it.sauronsoftware.ftp4j.FTPClient.login(FTPClient.java:1186)
at COM.safe.fmeserver.relay.plugin.ftpwatch.FTPWatchPollingThread.loginToFTPServer(FTPWatchPollingThread.java:454)
at COM.safe.fmeserver.relay.plugin.ftpwatch.FTPWatchPollingThread.poll(FTPWatchPollingThread.java:139)
at COM.safe.fmeserver.relay.plugin.ftpwatch.FTPWatchPollingThread.run(FTPWatchPollingThread.java:111)
The ftpcaller with parameters "binary / passive / Verify SSL / Password" work with the same site.
Does anyone already experienced this kind of issue ?
Is there any way to add parameters or control the FTPWatcher in FME Server ?
EDIT :
the ftp_watch works with subscriptions but not within automation. I'm puzzled :/
Versions :
FME Server 2019.2 / Build 19735 - linux-x64
Thanks for your help or advices !
nampreetatsafe
Forum|alt.badge.img+13
Hi @egenestine! Thanks for the details. Looks like build 19735 was a Beta build. Would you mind giving it a shot with an official release and let us know if you have any luck with that?
According to @lauraatsafe here https://knowledge.safe.com/answers/96246/view.html, the FTP Watch should work with FTPES within Automations.
We're curious to hear if you have any luck with an official release.
I've upgraded FME server but with no luck. It works fine with triggers but I think it's a tricky solution for someone without strong technical knowledge and I definitely prefer using automation for this kind of process as I won't be the end user.
Is there any parameter that switch on more details in the logs ?
what kind of useful information should I enable/trace that would help me and lead to a solution ?
Thanks,
Eric
_fabian_
Forum|alt.badge.img+5
  • February 18, 2025
The Issue still persists in FME Flow 2024.2.3. I suspect that the FTPS Server (Bitvise SSH) sends the message “234 Security mechanism set to TLS” but the ftp4j plugin used in FME Flow only expects a number in the response (see the readFTPReply function), or FME Flow just handles the resposne incorrectly.
Any chance this will get fixed?
siennaatsafe
Forum|alt.badge.img+11
Hi ​@_fabian_ ,
I'm sorry you're encountering this issue. I haven't come across any other reports in our current build, so it looks like we’ll need to file a new ticket for our development team to investigate and resolve this.
Could you please file a support case so we can follow up with you directly? Your help in providing more details will be much appreciated.
Thank you for your patience
