Failure UPDATING existing versioned ArcPro sde table with Esri Geodatabase (ArcSDE Geodb) writer.
  • Jun 7, 2023 7:31 PM UTC
  • 5 replies
  • 262 views
Currently trying to UPDATE isolated features within an existing Versioned sde table (ArcPro Only) using the Esri Geodatabase (ArcSDE Geodb) writer.
Considerations:
  • Schema has been Imported from Dataset
  • Transaction Type has been set to: Versioned Edit Session
  • Successfully written to a TEST.gdb
  • Table has been READ into workbench, joins and ETLs applied to data, then attempting to WRITE to same table back in SDE
  • Have toggled Ignore Relationship Info to no avail
Error Code:
  • Error while updating feature in the table/feature class 'Addressing'. The error number from ArcObjects is: '-2147207389'. The error message from ArcObjects is: {}
hkingsbury
Forum|alt.badge.img+73
  • Jun 7, 2023 8:15 PM UTC
A couple of things to check:
  1. Do you have 64 bit background geoprocessing installed (if using arcmap)
  2. Are your FME and Esri versions compatible? - https://community.safe.com/s/article/notes-on-fme-and-esri-versions-and-compatibility
There's a discussion about the same issue here:
https://community.safe.com/s/question/0D54Q000083BMHUSA4/how-to-solve-this-error-message-the-error-number-from-arcobjects-is-2147024893
  • Jun 8, 2023 1:45 PM UTC
Hi hkingsbury,
  1. I have ArcDesktop 10.8.1 installed on my computer which appears to have 64-bit background geoprocessing out of the box. That being said, the workbench I am running is utilizing ArcPro (Installed ArcGIS version is '2.9.5').
  2. I am using: Current FME version: FME 2022.2.0.0 (20221103 - Build 22765 - WIN64) which appears to be compatible with the ESRI version I am using (ArcPro 2.9.5) and ArcSDE 10.0.
Let me know if this answers your checks.
  • Jun 8, 2023 7:24 PM UTC
Hi hkingsbury,
Redownloaded 64-bit background geoprocessing to test this theory and this did not appear to affect the result.
From what I can tell, FME and Esri versions are compatible as well (FME 2022.2.0.0) + (ArcPro 2.9.5).
Any other thoughts?
hkingsbury
  • Jun 8, 2023 10:09 PM UTC
A couple of checks you could do is:
  1. check that you can make the edits in ArcMap
  2. check that you can make edits to other versioned tables in FME
  3. disabled versioning, check edits work, then enable versioning again and check if edits still work
  • Jun 12, 2023 6:44 PM UTC
Hi hkingsbury,
  1. The table is ArcPro online as it is configured for use with Attribute Rules. The following is the message I receive when I attempt to open in ArcMap:image
  2. I received the same error (Error while updating feature in the table/feature class 'GISADM.RD_ROADNAME'. The error number from ArcObjects is: '-2147207389'. The error message from ArcObjects is: {}) when trying to edit another versioned table in FME
  3. I am beginning to think the issue revolves more around the ArcPro Attribute Rule error opposed to the table being a versioned dataset. As I will have to involve other departments to toggle the versioned status, I will explore this route before testing the versioning (turn off).
Thanks!
