ESRI task in FME
  • Nov 13, 2012 9:40 PM UTC
  • 70 views
With Arcmap you have the function "select by location"
How can i reproduce that function in FME?
Thank you
Gretings
Kees
  • Nov 13, 2012 9:59 PM UTC
Hi Kees,
There are lots of way in FME to perform the same functions, specifically the SpatialRelator and SpatialFilter transformers give things like interests, contains, within etc.
But then there are the overlayer transformers which can be slightly different but very useful (just type overlay in the transformer gallery search) and there are numerous versions of these.
I do recommend reading the transformer descriptions because there a lot more option in FME and you want to make sure you are using the transformers in the correct way. One hint  is that you need to have the data in the same projection when it reaches these transformers, as the data doesn't "project on the fly" within FME.
Cheers,
Todd
jlmiserez
Hi Kees,
The answer to what you want most likely lies in the family:
  • PointOnAreaOverlayer
  • LineOnAreaOverlayer
  • AreaOnAreaOverlayer
depending on what you want to do.
As the ArcGIS fuction does a lot of things, you may have to use a Bufferer before the actual transformer.
Hope this helps!
Greetings,
Jean-Luc
