ESRI licensing *cough nightmare* on FME Server
  • Aug 21, 2013 12:55 PM UTC
  • 51 views
sigtill
Forum|alt.badge.img+25
One question.
How can I make sure that a workspace only runs if it has an ArcInfo license available? That is - I want to check out the license before running the workspace (For instance in the python-script) ?
Not sure if this approach GUARANTEES that the license will not be used by someone else between the startup script and after a long processing (1 hour) starting the writer?
Related:
http://fmepedia.safe.com/AnswersQuestionDetail?id=906a0000000cgTFAAY
  • Aug 21, 2013 1:09 PM UTC
Hi Sigbjørn,
have you looked at this?
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//002z0000000z000000
Here is another way to check out a specific ArcGIS license:
try:
    import arcinfo
except:
    print "No ArcInfo license available"
Note that you will have to use the Python interpreter that was installed with ArcGIS for this to work, it will normally be something like C:\\Windows\\SysWOW64\\python26.dll if you're on a 64-bit OS.
David
sigtill
  • Aug 27, 2013 4:30 AM UTC
Thanks. Unfortunately it seems to request another Python-interpreter as mentioned by you. And changing the interpreter on Desktop and Server is not a good solution for the moment.
Your short script
try:
    import arcinfo
    print "ArcInfo license available"
except:
does not fail - but does not print anything either (I guess it also needs the Arcgis python-interpreter.)
