Does FME support connecting to Azure SQL Data Warehouse or Snowflake?
  • September 9, 2020
  • 41 views
Does FME support connecting to Azure SQL Data Warehouse or Snowflake? We want to be able to connect to and move data from either (or both) of those data sources into postgresql.
  • September 9, 2020
Hi @mmirobelli​
Whilst I haven't personally read any data from Azure SQL Data Warehouse, you could try this Reader first.
If that doesn't work, it looks like it's possible to connect using ODBC/JDBC, which FME does support.
Azure SQL DW Connection strings examples
FME ODBC doc
FME JDBC doc
  • September 14, 2020
jlutherthomas wrote:
Hi @mmirobelli​
FME ODBC doc
FME JDBC doc
Thanks for the information. I upgraded to 2020.1 in order to access the Snowflake reader/writer. I'll try the recommended reader(s) for Synapse Analytics.
