Open
Support Base64 encoded parameters in OAuth 2.0 Token Service
Related products:FME Form
tcrossman
kweller
  • tcrossman
    tcrossman
  • kweller
    kweller
gabriel_hirsch
When managing web connections in FME Form and creating a new Token Service (OAuth 2.0 Credentials Flow) we need the possibility to base64 encode the consumerKey and consumerSecret in the header according to the following pattern: "Authorization: Basic <base64 encoded consumerKey:consumerSecret value>"
The current workaround is to bas64 encode the requested information with the TextEncoder transformer and then hard code the encoded value(s) in the web connection template which isn’t that generic.
JennaKAtSafe
Hi ​@gabriel_hirsch, I agree — the extra step to encode to base64 could definitely be streamlined. We’ll explore this idea further! I could also see it being useful in the HTTPCaller in certain cases.
JennaKAtSafe
NewOpen
